State Reffing a B16A2
hello i am new here on the forums and i need some help with my car..i'ts a 96 civic hatchback with a stock B16A2 i was wondering what i would need to Bar'd my car? I live in California. My car has a Hondata s200 ecu, 98+ type r headers, and 98+ type r muffler. Everything else besides that its stock. and i was wondering about my gas tank..what gas tank should i use?
You need:
stock b16a2 headers with heatshield
stock P2t Ecu
catalytic converter
evape purge solenoid valve from b16a2 manifold if you dont have it already..
receipt for the motor and proof of purchase
Stock 99 civic si air intake black box
Wires have to look neat with sparkplug covers and so on..
Battery tie down hardware
No check engine lights
Basically everything that came off the 99 civic si engine
tip: use the 99 civic si stock ecu.. if you get any codes then you must fix them.. if you fix all of them, then your good to go..
stock P2t Ecu
catalytic converter
You need:
stock P2t Ecu
catalytic converter
stock P2t Ecu
catalytic converter
that sums it up but 1 important thing is U NEED ALL readiness monitors to be ready to ready to be able to pass
gl
You need:
stock P2t Ecu
catalytic converter
stock P2t Ecu
catalytic converter
i bought the motor off of my friend..i have no papers for it but its a legit motor with vin # still in place..how else will i get papers for them?
and thx for ur reply info really helped.thx guys
You need:
stock P2t Ecu
catalytic converter
stock P2t Ecu
catalytic converter
well i dont have any paper work for my motor but its legit..i bought it off my friend couple years ago it still has vin # on it...
and thx for ur reply info helped alot
Definately gonna have to change the ECM. If the headers and exhaust appear stock you may get away with it. Like if they have the original heat shields and such. But if you have CARB_EO stuff then you should be ok.
You also need a 99 or 00 gas tank because those gas tanks have a sensor for pressure and if you don't have it the 99 si ecu will throw a code.
this is what readiness monitors are..u need a scan tool to check if they are complete or not complete
