98 GSR -Can loose valves cause bad compression
well here the thing for some reason my car was acting funny. like it was sputtering so i checked my plugs they were ok except for one.the one that was bad had a crack in porsolin where the sparkplug wire meets. so i change them out with new ngk v powers still had the same problem. then i figured i just do a compression test found out i got low compression 3 out of 4 cyclinder 160-170-220-170. no leaks at all no smoke either. i do hear my engine clicking tho i was wondering can loose valve cause low compression? the head was redone 6 months ago had 220psi all across when i check it while back
thanks for reading hopefully someone can give me some advice on what to do
no loose valves wont cause a low compression situation, being to tight can cause an issue cause they wont close all of the way, a valve adjust might be a good start tho, might have some tight and some loose, plus it doesnt really cost anything if u can do it your self
160k on the block just did the head 6 months ago i did a leak down test while back it was coo can it get tighter out of no were it was fine like a week ago
H22AFerio
Oct 9, 2011 11:23 AM
LostGsr
Jun 15, 2001 12:29 PM
