Vtec Pressure Switch Voltage ?
Old Apr 21, 2009 | 07:19 PM
Nisif's Avatar
Default Vtec Pressure Switch Voltage ?
A friend of mine has a EG with a B16 swap. Car is throwing cel code 22 for vtec pressure switch.
I believe there is an issue with the wiring to the pressure switch. The black wire is running to a good ground and the blue/black wire is running to ecu input D6.
Should the wire from pinout D6 provide 12 volts ONLY at the rpm when vtec engages?
Old Apr 21, 2009 | 08:48 PM
Nisif's Avatar
Default Re: Vtec Pressure Switch Voltage ?
ttt
skoodles2k6
Apr 14, 2008 07:29 PM
nutball72
Aug 26, 2006 10:54 AM
iNERtIA
Apr 3, 2006 09:42 PM
Bump
Sep 28, 2005 04:12 PM
tinkerbell
Jan 1, 2005 08:00 PM
