90 awd wagon converting to fwd
looking to put in an ls motor in my wagon thats awd but removing all my awd stuff. do i need to get new trailing arms or can i just pull the rearend out and the rear axles?
by the way does any one need awd stuff?
got motor trans trans case driveline and rear end
the trailing arms should work without the axles just fine. perhaps you should sell the awd wagon completley or trade plus cash for one youd want, it seems to be a shame to rip out the awd thats working perfectly fine i pressume.
the rear bearings will come apart with no axles in them, you could gut the outer cv's and just put them back in but I'm with everyone else, keep the rt4wd!
just ef it: you will also need the rear trailing arms if your trying to do a swap, also will have to cut and merge the trailing arms, or was it shorten them....but something like that in order to swap them into the hatch/crx chassis.
Your Name
May 15, 2009 02:21 PM
