Diffrences in JDM D15B & D15B7?
Old Apr 21, 2009 | 02:55 PM
TravisCadello's Avatar
Default Diffrences in JDM D15B & D15B7?
is the JDM block stronger or better or whats the differences in blocks?
Old Apr 21, 2009 | 02:58 PM
hannslebo's Avatar
Default Re: Diffrences in JDM D15B & D15B7?
D15b
Old Apr 21, 2009 | 02:59 PM
How? whats changed in them?
Old Apr 21, 2009 | 03:13 PM
hannslebo's Avatar
well i read the question wrong i thought you were asking which one would i take...sorry for the misteak!! but here are some specs on both.
i do belive that the JDM motors are stronger....dont quot me tho!!
D15B
Found in :
1991-1999 Honda Civic VTi EG4 (Japanese Market)
1992-1998 Honda CRX VXi EG1 (Japanese Market)
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in)
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.6:1
Power : 130 hp (96.9 kW, 132 ps) @ 6800 rpm
Torque : 103 ft·lbf (14.1 kg/m, 138 Nm) @ 5200 rpm
Redline : 7200 rpm
Fuel Cut : 7411 rpm
Valvetrain : SOHC VTEC (4 valves per cylinder)
VTEC Switchover : 4200 rpm
Head Code : P08
Piston Code: P08-010
Fuel Control : OBD-1 MPFI
D15B7
1992-1995 Honda Civic CX (Canadian model)
1992-1995 Honda Civic DX/LX
1993-1995 Honda Civic del Sol S
1992-1995 Honda Civic LSi Coupe (European Market)
Compression : 9.2:1
Power : 102 hp (76.1 kW, 103 ps) @ 6200 rpm
Torque : 98 ft·lbf (13.5 kg/m, 133 Nm) @ 3800 rpm
Valvetrain : SOHC (4 valves per cylinder)
Piston Code : PM3
ECU: P06
Old Apr 21, 2009 | 04:02 PM
Smash03's Avatar
Basically,
D15B - vtec
D15B7 - nonvtec
Old Apr 21, 2009 | 04:51 PM
CivicSpoon's Avatar
Internally they are very different; different heads, different crankshafts, different pistons, different rods. The D15B might be "better" in the sense that there are far more aftermarket parts available. Try searching for aftermarket connecting rods for D15B7, and then try searching for rods for the D15B. Since the D15B shares the same rods as the D16Z6, there are more options available.
Old Apr 21, 2009 | 06:16 PM
Ok, i know the head is better but the internals of the block only. compared to the b7 and z6?
Oh ****, and the PM3 pistons are d15b7's only? because when i had the head off it had pm3 pistons. does this mean its not JDM pistons?
Old Apr 21, 2009 | 06:22 PM
cashkeith's Avatar
d15b has 130hp and d15b7 has 102hp and non vtec
Old Apr 21, 2009 | 06:26 PM
Look, I'm not asking power because my set up is WAAY different than the dam full D15B setup. Its running a Y8 head and p28 ecu.
My reason asking is because i wanna know if I'm safe when I'm doing 7750RPM shifts, I felt safe with the Z6 block but im aware this one is a little different i need to know if the internals can take high rpms or not.
Crank,Rod,Piston,wrist pin, rod bearings, oil pump everything beneath the head! thanks.
Old Apr 21, 2009 | 06:35 PM
bump?
Old Apr 22, 2009 | 01:53 AM
24TEN's Avatar
PHANTOM MENACE
If I'm not mistaken, there are also D15B blocks that are literally the same as a D15B7. I had a replacement motor in my EF when I first got it. It was stamped D15B but it too had PM3 pistons in it.
Old Apr 22, 2009 | 02:59 AM
sicksol93's Avatar
I have a D15B swap in my del sol si, with a t3/t4 turbo, pushing 10lbs of boost with stock internals. I definatlly can't complain.
Old Apr 22, 2009 | 08:44 AM
isn't that weird? why would it have usdm pistons? and did you get your from japan?
Old Apr 23, 2009 | 02:04 AM
24TEN's Avatar
PHANTOM MENACE
Yes it was a replacement motor from Japan.
Old Apr 23, 2009 | 08:03 AM
honda.lioness's Avatar
Reinforcing those who indicate they know that there is both a JDM D15B vtec and a JDM D15B non-vtec. The non-vtec block and head are similar or identical to the USDM D15B7. See for example http://www.cr-x.org/home/jdmspecs.html , http://www.honda.co.jp/HOT/ModelData...09b/mx_sy.html (google for a Japanese to English translator, though most of the numbers need no translation), and http://honda.lioness.googlepages.com...15benginenotes
Travis, why is it you think PM3 pistons are only USDM? I do not think this is so.
Old Apr 23, 2009 | 11:44 AM
it not that i think that, but people had told me that. so their are JDM pm3 pistons. hmm so its still a good block i guess.
Old Nov 29, 2015 | 05:43 PM
sako peelo's Avatar
Hi guys,
I have a 92 Del Sol running on a VTEC D15B JDM motor and i have been searching rebuild kits on ebay for upgrading to forged pistons and rings etc. however most of the rebuild kits are not compatible with the "JDM" D15b VTEC.
According to other blogs, researched that if there is no number on the engine ID (i.e. D15b1 D15b2 D15b7 .....) the engine is Japanese If I am not wrong?
So i need to know which one of the USDM rebuild kit would be compatible to the JDM D15b ?
Old Nov 29, 2015 | 05:51 PM
NotARaCist's Avatar
I never narc'd on nobody!
6 year old thread
Besides, you already have your own thread. You didn't need to necro this one.
Old Nov 29, 2015 | 06:52 PM
Former User's Avatar
Old thread locked.
accordingdone
Mar 28, 2010 06:30 AM
KRZRICAN
May 20, 2009 03:52 PM
efjones9
Dec 5, 2008 08:19 AM
