Need help on what to do to my setup next?
I have 92 cx with a itr motor (stock internals). The usual I/H/E with test pipe and I also have a AEM fpr not installed. I do alot of drag racing, My best time was 13.6 on street tires very good time I think. My question is what should i do to my car next to get more power. I dont know weather to get a clutch and slicks or better fuel pump rail and put on my AEM fpr. If you can help me steer in the right dirrection i will really appreciate it.
your stock fuel rail i plenty... no need to upgrade unless you want the bling bling look. I would get in this order:
22' slicks
jun/toda flywheel
FPR
cams(skunk2, jun,)
cam gears
higher comp pistions 11.5:1
traction bars
port and while your at it get some larger valves .5mm or 1mm oversize
with a decent driver you should get into the 12
[Modified by Charlie, 7:40 AM 8/16/2002]
22' slicks
jun/toda flywheel
FPR
cams(skunk2, jun,)
cam gears
traction bars
GQ 05YellowEVO8
Feb 9, 2002 09:06 PM
