Need help on what to do to my setup next?
Old Aug 15, 2002 | 07:33 PM
spart's Avatar
Default Need help on what to do to my setup next?
I have 92 cx with a itr motor (stock internals). The usual I/H/E with test pipe and I also have a AEM fpr not installed. I do alot of drag racing, My best time was 13.6 on street tires very good time I think. My question is what should i do to my car next to get more power. I dont know weather to get a clutch and slicks or better fuel pump rail and put on my AEM fpr. If you can help me steer in the right dirrection i will really appreciate it.
Old Aug 16, 2002 | 12:06 AM
AussieK24's Avatar
Default Re: Need help on what to do to my setup next? (spart)
Need more info to help. Need 60' and mph to see if you need more power/less weight or traction.....
Old Aug 16, 2002 | 04:38 AM
Charlie Moua's Avatar
your stock fuel rail i plenty... no need to upgrade unless you want the bling bling look. I would get in this order:
22' slicks
jun/toda flywheel
FPR
cams(skunk2, jun,)
cam gears
higher comp pistions 11.5:1
traction bars
port and while your at it get some larger valves .5mm or 1mm oversize
with a decent driver you should get into the 12
[Modified by Charlie, 7:40 AM 8/16/2002]
Mr. EF
Jan 29, 2009 12:21 AM
LSTEG96
Oct 30, 2003 08:18 PM
GQ 05YellowEVO8
Feb 9, 2002 09:06 PM
