another rear sway bar question (reinforcment)
after searching through a bunch of post on rear sway bars, i've decided i want to get one that bolts directly to the subframe instead of the one that bolts to the tow hooks..
i found this post about subframe tear out with bars mounted away from the subframe
https://honda-tech.com/zerothread?id=248163
and since i have some si lca's i wanted to know if there are any reinforcement kits for the ef chassis..
also who manufactures rear sway bars that bolt onto the subframe?
thanks
[Modified by CIVICtypeS, 4:28 AM 8/16/2002]
thanks
p1driftfiend
14
Feb 23, 2004 12:18 PM
