Suspension & Brakes Theory, alignment, spring rates....
rear wheel hub vibrating and shaking at HPDE
Old Apr 21, 2009 | 05:08 AM
AlphaKennyWun's Avatar
Default rear wheel hub vibrating and shaking at HPDE
did an HPDE and under hard turning, felt one side rear wheel shaking and vibrating. Pulled on the wheel and no play. I have stock 1991 suspension on an ef. nothing is apparent after a visual inspection. Is it the bearing starting to go or end link bushings old or shocks? what should i check or replace first?
Old Apr 21, 2009 | 10:30 AM
Tyson's Avatar
Default Re: rear wheel hub vibrating and shaking at HPDE
lift the corner and spin the wheel by hand. listen and feel for any sort of roughness. it can be hard to distinguish over the brake drum sometimes, but it can be obvious too.
otherwise, maybe you have a flatspotted tire.
Old Apr 21, 2009 | 10:43 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yeah on a car like that with no ABS, and braking during hard cornering, it would be pretty easy to lock up the inside rear wheel.
Do you feel any vibration while driving straight/normally?
Old Apr 22, 2009 | 05:49 PM
No vibration when driving straight but the car and the bearings are 20 years old. Its not going to hurt to start by replacing the bearing. From what I felt that is my first instinct where its coming from.
Dub9.Juice
Sep 24, 2009 01:29 PM
EJ8 GSR-T
Feb 22, 2009 05:28 PM
vtfootball54
Jan 22, 2007 04:32 AM
.I.Need.Money.
13
Dec 31, 2006 09:47 AM
ludeR917
Oct 22, 2004 05:57 PM
