Suspension & Brakes Theory, alignment, spring rates....
I failed...
Old Apr 21, 2009 | 12:07 AM
SlowEJ8's Avatar
Default I failed...
So researched a lot up on konis, but for some reason i really messed up here, and what a dumb mistake.
Ordered it from a vendor, and i found out the one i have is only 5 levels of adjustability, assuming the regular ones.
Now what i wanted to know is that is there a huge difference or is more levels of adjustability really needed??
Is it really that bad compared to sp3/race etc, can anyone tell me???
I got it for the normal price the 5 level adjustables ones btw. But just wondering if i should return and upgrade... thanks
Old Apr 21, 2009 | 04:04 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: I failed...
Are you talking about perch settings? Normal Koni Sport shocks have 2 perch settings for the front shocks, and 3 rear settings. The Neuspeed versions have 5 settings all around and the droop limiter on the shock piston.
Old Apr 21, 2009 | 10:34 AM
Tyson's Avatar
yeah, youre mistaken and confused about something.
the shock rebound is adjustable without any tick marks between full soft and full hard, so they say its "infinitely" adjustable.
the height adjustment perches have 2-5 "levels", or positions, as patrick explained. if you have the neuspeed ones, theyre pretty much the same as regular koni yellows. really no difference, just more perch settings and a droop limiter internally that really does nothing.
what is it that youre tripping about?
Old Apr 21, 2009 | 12:29 PM
SlowEJ8's Avatar
Ah. Alrite then, i thought it was only 5 levels of shock rebound adjustability. Thanks
PURPLERANGER
Suspension & Brakes
Jun 20, 2013 09:56 AM
kevs-ej1
Suspension & Brakes
Mar 30, 2010 06:40 AM
onesikcivic
May 13, 2004 09:47 AM
integerkgsr
Feb 21, 2004 10:52 AM
reefer_bob
Jun 5, 2002 02:04 PM
