SPRING RATE THREAD **searched**
i've searched for atleast an hour now and can't find spring rates for coilovers or lowering springs.
please post up spring rates of coil overs what car/engine ur using with it. ill try to move and keep useful info in the first post.
zomg i found this on clubeg6.com
Originally Posted by \\ Forgiven //
There are a TON of threads with the same questions being asked. "Should I buy x coilovers?"
"How stiff are x coilovers?"
"What is the best suspension for me?"
Well racinmason suggested that a sticky be created with all spring rates so that people don't have to keep asking and having others look them up. I personally am tired of reciting spring rates to everyone, and I can only imagine how racecivicman must feel so here you guys go.
First, let me start by saying that stiffer is NOT always better!
That cannot be stressed enough. A suspension that is too stiff will limit suspension travel too much. This can cause decreased tire contact with the road in turns, which means decreased traction and can be very unsafe in certain circumstances.
Second, keep in mind that the stock suspension is perfect for street comfort. If you want your car lower, but still want great comfort, grab a spring that is as close to the stock rates as possible.
Your suspension should be chosen according to your driving habits. I know a lot of you weekend ricers want the best performance for your daily driven cars, but a daily driver is just that. You don't need race spec coilovers on your grocery getter. If your car has never seen a track in its lifetime, stay close to the factory spring rate. You'll only look foolish bouncing down public road, and your *** isn't going to feel too great after an hour or so of steady driving.
Here is a list of commonly used coilovers and lowering springs and their respective spring rates. When looking at this list, please keep in mind that the factory spring rates are around 3k (165 in/lb) Front and 1.4k (80 in/lb) Rear.
Buddy Club N+ Spec Dampers:
Front - 10k (560 in/lb)
Rear - 7k (392 in/lb)
Buddy Club Racing Spec Damper:
Front - 12k (672 in/lb)
Rear - 8k (448 in/lb)
Buddy Club P-1 Racing Damper:
Custom Orders Only. Call for available rates.
KSport Control Pro:
Rear - 6k ( 336 in/lb)
Skunk2 Pro-S:
Front - 8k (448 in/lb)
Rear - 6k (336 in/lb)
Skunk2 Pro-C:
Skunk2 Adjustable Coilover Sleeves:
Street:
Drag:
Rear - 18k (1008 in/lb)
Skunk2 Lowering Springs:
Front - 9k (504 in/lb)
Rear - 5k (280 in/lb)
Progress Technology Coilovers:
Front - 6.25k (350 in/lb)
Rear - 4.5k (250 in/lb)
Stance GR+ Coilovers:
Function Form Type II Coilovers:
Custom order rates from 6k (336 in/lb) to 13k (728 in/lb) Front and Rear
Ground Control Coilover Sleeves:
Omni Power Full Body Coilovers:
Sport:
Rear - 10k (560 in/lb)
Street:
Omni Power Coilover Sleeves:
Tein H Tech Lowering Springs:
Front - 3.4k (190 in/lb)
Rear - 2.3k (129 in/lb)
Tein S Tech Lowering Springs:
Front - 3.8k (212 in/lb)
Rear - 2.5k (140 in/lb)
Tein Basic Coilovers:
Front - 7k (392 in/lb)
Rear - 3k (168 in/lb)
Tein SS Coilovers:
Rear - 4k (224 in/lb)
Tein FLEX Coilovers:
Front - 9k (503 in/lb)
Tein MONO FLEX Coilovers:
Front - 14k (783 in/lb)
RS*R ti2000 Drop Springs:
Front - 4.3k (242 in/lbs)
Rear - 3k (168 in/lbs)
RS*R Drop Springs:
Neuspeed SoftSport Springs:
Front - 4.6k (260 in/lbs)
Rear - 2.7k (150 in/lbs)
H&R OE Sport Springs:
Front - 5k (280 in/lb)
.75" drop
Rear - 3.4k (190in/lb)
.75" drop
H&R Sport Springs:
Front - 5.9k (330 in/lb)
1.8" drop
1.6" drop
*NOTE: The following setups I could only find for the EK Chassis, but I included them since they fit our cars with a little modification*
Tein Type HT Damper:
Front - 20k (1118 in/lb)
Tein Super Racing:
Front - 22k (1230 in/lb)
Rear - 14k (783 in/lb)[/b]
KSport Control Pro:
Skunk2 Pro-S:
Skunk2 Pro-C:
Street:
Drag:
Sport:
Street:
Tein SS Coilovers:
RS*R Drop Springs:
.75" drop
.75" drop
H&R Sport Springs:
1.8" drop
1.6" drop
Tein Super Racing:
1320fuel.com
Jan 21, 2014 03:04 PM
ViruX
Dec 15, 2002 01:32 PM
