New pistons in my ZC question
Old Apr 20, 2009 | 06:41 AM
misha's Avatar
Default New pistons in my ZC question
A while ago i came across a magazine that was indicating that d15b7 could upgrade its power with first gen integra pistons(d16a1)
Right now i got a sohc non-vtec ZC, originally came from a carburetor car, i am running it with MPFI. Its burning oil, i already did the seals, but now i need to do the rings on it.
So while i tear it all apart i was thinking that new pistons with a bit of the power upgrade would be nice.
So would the d16a1 pistons work in SOHC ZC successfully?
and would i have to change the rods or i can use stock? May be there is anything else i need to change to make those pistons work?
Thanks
m-
Old Apr 20, 2009 | 06:42 AM
misha's Avatar
Default Re: New pistons in my ZC question
im not sure what happened with the font, sorry about that.
Old Apr 20, 2009 | 07:31 AM
jlicrx's Avatar
the D16A1 pistons will work in the SOHC ZC using the stock rods - the 86-87 D16A1 pistons will give you compression ratio of about 10.5:1 - the 88-89 D16A1 pistons will give you compression ratio of about 10.8:1
Old Apr 20, 2009 | 09:30 AM
88_acED6's Avatar
put a y7 head on it to bump the comp higher
Old Apr 20, 2009 | 11:41 AM
misha's Avatar
so 88-89 is the way to go then, using stock ZC rods
woudl i experience any issues with the timing?
Old Apr 20, 2009 | 06:46 PM
misha's Avatar
anyone else?
Bserieskiller
Jan 8, 2020 07:24 PM
Dc2 Joe
Apr 2, 2006 07:32 PM
Dc2 Joe
Mar 30, 2006 03:55 PM
DOHClessEF-9
Jan 28, 2005 12:01 PM
bscvc99
Jan 13, 2005 06:08 PM
