engine bore
Old Apr 19, 2009 | 05:46 PM
gsr96cx's Avatar
Default engine bore
What is the biggest you can bore a jdm b18c block to, without having to sleeve the block? 82mm? ITR, pr3 or p30 pistons? Running with a p72 head. My machine shop said I can bore it out to 82mm max without having to sleeve it so I was just carouse if it was true.
Old Apr 20, 2009 | 07:26 AM
Dave_Dc2's Avatar
Default Re: engine bore
yes that is true on stock sleeves..the thing u must be aware of. if this is going to be a boosted engine u dont want to thinin the sleeves too much..all motor will be fine
Old Apr 20, 2009 | 09:23 AM
gsr96cx's Avatar
Thanks for the reply, and yes this will be for a NA setup.
Old Apr 20, 2009 | 09:24 AM
gsr96cx's Avatar
Does anyone know if RS machine have reliable pistons, and rings? They are the only that will have 82mm ITR spec pistons? Or is the Nippon pistons better?
kgreenhaw
Aug 3, 2012 12:24 AM
MikeSarr_GSR
Sep 25, 2007 05:45 PM
I_got_your_honda
Aug 17, 2006 01:04 PM
camlob
Apr 22, 2006 01:42 PM
Cyber ITR
Apr 11, 2002 12:25 PM
