Quality downpipes *searched*
The most standard ones are from Spoolin', Peakboost, Full-race, SLS and AFI. But fitment can only be guaranteed based upon the manifold that you used. It does not good to get a downpipe from a kit in which you don't have the matching exhaust manifold for your application.
Just get a 4 bolt flange in the correct diameter and make one yourself or having a shop make it for you. Best to make it custom unless you have a kit...
We could make you one, we would need the manifold though. Our downpipes tuck up high so ground clearance is not an issue, and its made to bolt up to where a stock header would bolt to.
You can check out more pics here
http://www.rcautoworks.com/gallery
theauthor17
Aug 8, 2008 11:47 AM
