Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
TB heat system delete
Old Apr 17, 2009 | 08:45 PM
kartman5's Avatar
Default TB heat system delete
Could'nt find this on the search mode. I'm wondering how hard it is to delete the system
that heats the TB. It seems as though this would be something you would want to delete
if you lived in a warm climate. I'll be adding the TB spacer at the same time.
Thanks,
Old Apr 17, 2009 | 11:10 PM
i-VTEC_DOHC's Avatar
Default Re: TB heat system delete
Thanks,
ok well the inlet and outlet for the coolant is on the bottom of the front side on the tb. u take out the hose farthest from you, which is the inlet, and u put a nipple in it. then you take out the other hose closest to you, which is the outlet, and u put it on the nipple. then u clamp em both and you're good to go. dont forget to plug up the holes on the tb that will be left open.
Old Apr 18, 2009 | 11:08 AM
Zeusone's Avatar
just remove one of the hoses from the throtle body. with the other hose put it where the other one was to create a loop. flush it first by pouring water into the end of the hose. now ith the other end of the hose plug it into the side you removed that has coolant.
Old Apr 18, 2009 | 12:21 PM
ironworker's Avatar
What would be the advantage of doing this? Thanks
Old Apr 18, 2009 | 01:15 PM
kartman5's Avatar
I believe that by cooling the temperature of the air going into the intake manifold you
can acutally increase hp. The engine runs better with cooler temps on the intake side,
much the same way a CAI would work.
Old Apr 18, 2009 | 05:43 PM
yea it reduces the temperature of the air entering the motor.
there are obviously advantages and disadvantages.
advantage is that u get cooler air temps and a lil more power.
disadvantage is when it gets cold, well if it gets below freezing in your area,
u risk the possibility of freezing the tb shut.
it happened to me last winter and i decided its not worth it for me to risk it again.
but its a simple fix. all u need is a heat gun.
Old Apr 19, 2009 | 07:03 AM
dirtySOHC's's Avatar
really? all that for MAYBE 1 or 2 horsepower? if any increase at all.
save yourself the time.
Old Apr 19, 2009 | 02:45 PM
yea but most companies that make intakes call for it to get the most out of their product. cuz thats what my injen called for was a tb bypass, but i found a way around it
Old Apr 20, 2009 | 08:54 AM
miketat594's Avatar
You can also just add a shut off valve to the inlet hose , and flip it closed for the warm month's and flip it open for the winter.. Thats what I did, works great and you dont need to disconect and plug everything.
ska24
K Series
May 20, 2019 07:22 AM
AtoZ
Jan 17, 2009 11:33 AM
prelude_93vtec
Jun 24, 2007 04:42 PM
hotrod99
May 5, 2007 12:11 PM
Wiseguy619
Nov 28, 2003 03:28 PM
