no power
I have been working on installing glow gauges in my 99 accord for 2 days I have it all done except hooking up the power supply. Today the can started not wanting to start so I had the battery check, the said the battery was bad so I replaced the battery and all was good till I was trying to find the fuse that worked the dash lights to wire in the the new glow lights. the problem now is I have no power! the head lights work and the rtail lights work and the dome lights work but everything else is dead! No power when I turn the switch on! Anyone have any ideas? I checked all the fuses and they all look good unless it's a relay under the hood?
Since I got no replys to this question, And have found the problem myself. I'm going to give the answer in hopes it might save someone else the hassle of hunting down the problem. The 50 amp that is held in place with screws under the hood in the blace fuse box was blown. I had to take it out to see that it was blown.
Gage12
21
Jun 17, 2015 03:10 PM
