using d16y8 intake manifold on d16z6
Ok, the throttle cables have diffrent brackets from the z6 intake to the y8 and i have it geto now how should it be?
i can floor my gas pedal and only opens the throttle half way.
No because the Y8 has it mounting brackets differently. theirs 2 10mm holding it on the y8 and on my z6 manifold it had just 2 nuts that held and adjusted the throttle cable not this one though.
I believe it part number 12 and 6 but my z6 had the throttle cable only thing holding it was the 2 nuts that u adjust it with the y8 mani has 2 10mm bolt that hold the throttle cable.
Just go pick up a cable and bracket. Shouldn't cost you too much. I picked up a type R cable and bracket for my GSR motor in my EK for a little over 50. You shouldn't have a problem just running a new cable.
eg6sy
Jul 11, 2012 10:53 PM
ventturei27
Feb 1, 2010 07:45 PM
Wazup
Feb 21, 2006 11:26 AM
