hole in trans!!!
Old Apr 17, 2009 | 02:48 PM
hannslebo's Avatar
Default hole in trans!!!
i was backing up the other day and my front pass side fell off the driveway...and it hit my trans right where the clutch is...now i have a hole about the size of 3 fingers....so is this going to hurt it??? and how can i repair this w/out gettin a new trans or whatever??? plz help asap...struggling college kid!!!!
Old Apr 17, 2009 | 03:02 PM
EG6KILIN's Avatar
Default Re: hole in trans!!!
Were is the hole located is it by the clutch bleeder thing
Old Apr 17, 2009 | 03:10 PM
90Rexx's Avatar
post a pic. if its on the bell housing you can just mickey mouse a fiberglass patch and you will be fine. you only need it to prevent debris from entering the bell housing.
Old Apr 17, 2009 | 03:11 PM
hannslebo's Avatar
the hole is on the bottom of the trans...where the hole is i can see the teeth to my clutch/flywheel???
Old Apr 17, 2009 | 03:14 PM
90Rexx's Avatar
yah your fine, just jimmy rig a patch so crap doesnt get in there. fiberglass , duct tape lol.... whatever works is fine. theres no danger of like fluid leak or anything so dont stress over it, its even mildly driveable as is, you would just chance getting debris in the clutch or flywheel and causing damage. i would buy a fiberglass kit from autozone and patch it up lol.... but then again some call me a hack, but then again, you are a struggling college student?
hannslebo's Avatar
there is also fluid around it...soo just clean it off good and rig myself a patch???
Old Apr 17, 2009 | 03:21 PM
hannslebo's Avatar
sorry fellas...no fluid is leaking from my hole in trans...its coming from my master clutch cyl. around the rubber boot...any suggestions on a cheap fix for that as well..ha
Old Apr 17, 2009 | 03:42 PM
hannslebo's Avatar
bump
Old Apr 17, 2009 | 04:02 PM
BryanM.'s Avatar
Resident Gearhead
That's the clutch slave cylinder, not the master cylinder.
NAPA sells them for about $22. Cheap easy fix.
Old Apr 17, 2009 | 04:14 PM
hannslebo's Avatar
thanks for the quick help guys...and will i need to bleed the slave cyl. or just put it right on???
Old Apr 17, 2009 | 04:25 PM
BryanM.'s Avatar
Resident Gearhead
Install it and bleed the entire clutch line, no big deal really.
Old Apr 17, 2009 | 08:04 PM
thumper64's Avatar
Don't use Duck Tape as a patch. It has it's uses, but it's only a temporary fix and won't hold up well to heat or petroleum. Fiberglass may work. What about JB Weld or Loctite Weld and a piece of soup can or something as a patch? You can get JB Weld and the Loctite stuff for like $5 at someplace like Home Depot or maybe even Walmart.
kallmijonx2
48
May 2, 2010 08:36 PM
jbrokos307
Jun 4, 2009 11:23 AM
esokol
Jan 9, 2006 12:12 AM
nubb
Mar 30, 2004 05:27 PM
