yellow/ black engine harness wires
Old Apr 17, 2009 | 08:00 AM
candyman206's Avatar
Default yellow/ black engine harness wires
I was wondering if anyone could explain where do the 8 yellow and black wires go to. I know 4 of them go to each injector. But I'm having problems figuring out the other 4. I saw one going to a red wire from the drivers side connector but it wasn't connected to it and was wrapped in heatshrink. I'm just trying to find out what this red wire does and what it connects to. Oh yea its an OBD1 ls harness. Same plug as some of the dizzy wires go to.
Old Apr 17, 2009 | 09:55 AM
1992Si's Avatar
Default Re: yellow/ black engine harness wires
I believe the 4 are injector ground wires.
PM Turbo-charged, Joe Simpson or ask the same question on d-series.org it may even be a sticky there.
I try to stay away from wiring...
Old Apr 17, 2009 | 04:38 PM
Blown90hatcH's Avatar
4 to the injectors
1 to IACV
1 to Purge cut
1 to O2 sensor
1 +12V Power into the connector for those listed above.
All +12V Power wires and not grounds.
Old Apr 18, 2009 | 03:05 PM
Alright....so it's the purge solenoid. Do you happen to know a way to bypass or is there no CEL for it.
Old Aug 12, 2024 | 08:38 PM
Gswapper97's Avatar
Originally Posted by Blown90hatcH
4 to the injectors
1 to IACV
1 to Purge cut
1 to O2 sensor
So i could tap my IAB positive to the 12V+ of the IACV to run my IAB's?
Old Aug 12, 2024 | 08:49 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yes.
thundernoodle
Sep 16, 2012 05:47 PM
EF9_TryMe
Dec 17, 2010 05:13 PM
ryanevansoh
Mar 27, 2009 04:06 PM
WickedWerx
Nov 1, 2004 08:18 PM
highmilehatch
Jul 24, 2003 02:09 PM
