Sqweeky problem comin from the rear of the car
so everytime i go over bumps n' stuff like that, it sqweeks a little in the back. has anyone else had this problem? if so, how did you fix it?
yeah i just got done sprayin wd40 on both rear shocks and it still does it, im startin to think it make be the bushings..., what do you guys think?
its the lca bushings. pretty positive. theres 3 bushings on each arm. where it mounts to the subframe, the suspension and the trailing arm. you can use silicone spray or wd40.
I had a squeak in the rear.. Changed struts/coils, nothing.. changed trailing arm bushings, nothing. Ended up being the rear upper control arms. The bushings were shot.
Spray some silicone spray on the bushings and see if the squeak goes away. If it does you know you need to replace them. Don't spray every bushing like I did.. Just do one at a time till you find it.
Mine was coming from the rear deck when pressure was applied.
When I go around turns or over bumps, the body will twist a little bit and the rear deck squeaks. wd-40 fixed it.
in my car its the arms that go from the underbody to the wheels. I just havent had time to fix it. One of the places whre it connects to the car got smashed in some crazyness which i dont want to get into.
Talldave
Jun 13, 2016 12:37 PM
