97 hatch turbo sohc for sale
Old Apr 16, 2009 | 09:40 PM
Garage 808 Hatch's Avatar
Default 97 hatch turbo sohc for sale
For sale is my recently finished DD. I was laid off today, so having a bit of a savings is more important than a fast DD. (by no means do I need to sell it, so keep low ball offers to yourself)
Graig 541-912-7069 PM me, call, text $7000 obo will lower price if I keep ecu
Roma red 97 DX hatch CLEAN TITLE
body could use some love, front has lots of rock chips, needs a rear bumper skin
Car make 352hp/250tq on 92 octane open DP
259/212 on low boost and 341/284 on high boost through full exhaust
CAR STILL HAS WORKING A/C
Just ADDED
redyno tuned low and high boost to clean up afr's, did a street tune. currently getting 32mpg from a nonvtec with aftermarket cam.
12" slim fans on radiator and a/c condenser
Garage 808 traction bars
Skunk2 upper A-arm camber kit
shimmed rear to -1* camber
ALSO, have a built Z6 head, P&P, comp springs and retainers, comp 59300 cam, SS valves, new guides and seals. When this goes on the car, price will go back up to 7500 obo
Skunk2 Pro-S coilovers
BLOX rear LCAs
Prothane rear trailing arm bushings
prothane shifter bushings
15" drag dr 16 red with polished lip
225/50/15 fronts 205/55/15 rears
8k HIDS
tunerview II large display
Alpine CD player (older but works great)
Integra front leather seats
Viper Alarm
THE ENGINE STUFF:
D16Y7 block
STD bore 75mm vitaras
H-beam rods
acl bearings
balanced rotating assembly
polished and chamfered crank
new oem oil pump, that I ported
new oem timing belt
new oem water pump
new oem headgasket
stock port D16Y7 head (50K mile head off a 2000)
delta regrind 262 cam
aem cam gear
Competition clutch stage 4, 6 puck sprung clutch
EX transmission
energy suspension mount inserts
CX racing 3 core aluminum radiator
12" slim fan
Turbo stuffs:
Just installed Skunk2 pro series Intake Mani with 61mm B16 TB
all aluminum, bead rolled charge piping 2.5" T-bolt clamps
CXRacing IC 28x7x3
SS log mani, built by James @ Garage 808
Holset Hy35 turbo
tial mvs 38mm v band wastegate
SS dump tube
SS 3" down pipe
full 3" exhaust with flex, 12"long resonator, and Vibrant flat black oval muffler
turbosmart dual stage boost controller
Omni power 3 bar map sensor (uses oem plug)
S300 with boost control parts installed
I'm sure i'm leaving out something
PICS
I will post more pics by the weekend of the new changes, IE new IM, exhaust
Old Apr 16, 2009 | 11:02 PM
StylishDOHC's Avatar
Default Re: 97 hatch turbo sohc for sale
can't believe.
Old Apr 19, 2009 | 06:46 PM
bump for new pics
new IM and redone piping
3" flat black muffler. full 3" exhaust
Old Apr 20, 2009 | 07:57 AM
JonathonTheZombie's Avatar
Bump Good running car
Old Apr 25, 2009 | 04:36 PM
bump for an 11 second car! bolted slicks on it and ran. full interior, on pump gas etc. #362
Old May 5, 2009 | 08:55 AM
Bump for a quick DD
Old May 10, 2009 | 10:31 AM
Bump it up
Old Jul 28, 2009 | 06:52 PM
Bump for updates and added stuffs
Old Jul 28, 2009 | 06:58 PM
BoostKiller's Avatar
that looks like damn good number for a y7
Old Jul 28, 2009 | 08:09 PM
FULLYBUILT2.0's Avatar
bump for same setup like my homie...single cams can rip @ss too
EK1project
Jul 21, 2011 01:40 PM
Garage 808 Hatch
Apr 19, 2009 06:49 PM
Coldness
Mar 17, 2006 10:09 PM
