ECT code (Water temp) help
Old Apr 16, 2009 | 08:05 PM
GSR-EG-92's Avatar
Default ECT code (Water temp) help
Just got finished my B18C install and the car is throwing a cel ECT (water temp sensor code 6). My question is would the motor start with this code normaly? Cause my motor wont turn over and I just wanna know if this is the issue or is its somthing bigger.
Also, is the code there because of a bad sensor or low coolant level?
Thanks for any info.
Old Apr 16, 2009 | 08:15 PM
Former User's Avatar
Default Re: ECT code (Water temp) help
A bad ECT sensor should not prevent the engine from starting.
Is the starter cranking the engine? Do you have spark and is the fuel pump priming?
Old Apr 16, 2009 | 08:18 PM
GSR-EG-92's Avatar
Starter is cranking, pump is priming, how do I check spark?
Old Apr 16, 2009 | 08:22 PM
Click here.
Old Apr 16, 2009 | 08:29 PM
GSR-EG-92's Avatar
Thanks for the info, Im going to check this tomarrow and Ill post back. If I dont have spark wouldnt that throw a cel?
Old Apr 16, 2009 | 08:31 PM
...If I dont have spark wouldnt that throw a cel?
Not necessarily.
Old Apr 17, 2009 | 06:52 PM
GSR-EG-92's Avatar
So Im pretty sure the engine is not getting spark, I cranked the motor again and took out one of the plugs, looked into the bore and saw a drop of fuel on the piston. Plus the plug felt cold to the touch right after cranking. Ron, I wanna try your method of checking for spark next, is there any danger in holding the wire and plug out while the car is cranking?
Old Apr 17, 2009 | 06:53 PM
GSR-EG-92's Avatar
A friend at work told me the energy of a spark plug can stop your heart, now Im spooked lol
Old Apr 17, 2009 | 07:07 PM
You risk blowing the coil if you don't ground the plug threads against a metallic area of the engine.
Old Apr 17, 2009 | 07:09 PM
Don't worry. Holding only the rubber part of the plug wire insulates your hand from electric shock as long as you ground the plug's thread against the metallic valve cover. You can wear rubber gloves as extra protection if you are worried.
Old Apr 17, 2009 | 07:24 PM
GSR-EG-92's Avatar
Ok I found 2 wires that were slightly de-pinned fromt the socket on the dizzy and I wasnt getting any spark, pushed them back in and the plugs are making a weak orange colour spark. Car still wont start but now it sounds like it wants to turn over and just isnt getting there. Maybe the engine is a little flooded right now.
Old Apr 17, 2009 | 07:26 PM
Weak orange spark generally indicates a bad coil in the distributor.
Old Apr 17, 2009 | 07:30 PM
GSR-EG-92's Avatar
Ya I read that in your DIY post you linked me, guess I ll have to go get it tested.
Old Apr 17, 2009 | 07:32 PM
You can either take the coil to an auto parts store for testing or check resistances yourself with a multimeter.
Melony O'Harra
Mar 28, 2014 07:12 AM
davidfillups
24
Mar 17, 2009 10:29 AM
REDREXMANB16
Nov 23, 2006 09:54 PM
rc90hatch
11
Dec 27, 2005 11:05 PM
Spence
Sep 29, 2004 08:39 AM
