quick fuel pump question
hey guys im currently running a b18 ls/vtec at 5 ps1 of boost with 450cc injectors tuned, but im running the stock fuel pump, is this bad? if i change it will it help at all?
Your tuner should have told you if your set up is getting lean. Chances are youre fine at 5 psi. The only reason you would want a new pump is if you want to run more boost. With your set up i'd get a walbro 255 and run 10psi, why only 5?
the REAL question, is 5psi on what turbo?
5psi on a T28 is going to be JUST alittle different then a GT4288R...
why dont people understand this?
Its less then 100$ for a walbro, get one.
You can pretty much assume that he will be dealing with a relatively small turbo.
Familycarfromhell
Jan 19, 2003 09:18 AM
