95 Civic EX Cluster swapped into 92 civic CX Hatch and now blinkers dont work! HELP!
Old Apr 16, 2009 | 09:46 AM
servemebeer's Avatar
Default 95 Civic EX Cluster swapped into 92 civic CX Hatch and now blinkers dont work! HELP!
Like the title says. Swapped in a 95 EX cluster and now the blinkers or hazards dont work. I put the old cluster back in and the blinkers and hazards still dont work. I replaced the turn signal hazard relay and still the same thing. I checked all fuses underhood and underdash and they are all good. Any help is appreciated!
Old Apr 16, 2009 | 10:07 AM
Laz's EP's Avatar
Default Re: 95 Civic EX Cluster swapped into 92 civic CX Hatch and now blinkers dont work! H
Make sure you check that all the cables are conected. Or maybe you pulled them out too much
Old Apr 16, 2009 | 10:51 AM
Check. Everything is plugged in. The speedo, odometer, fuel, and temp gauges all work fine. When I push the hazard switch in my radio shuts off though. I think my hazard switch is fried...
Old Apr 17, 2009 | 06:48 AM
OK, I replaced the hazard switch and the nultifunction turn signal switch on the steering column. There was a 7.5 amp fuse that was blown in the underhood fuse box. I replaced it. My blinkers still dont work and when I turn the key off and take it out the engine still runs! I have to depress the hazard switch to get the engine to turn off.
Anyone help here?
beefjerky
Apr 4, 2022 05:44 AM
Jalexck
Mar 22, 2014 07:26 PM
silverbullet9626
May 12, 2010 09:26 AM
1baddturbosi
Dec 15, 2006 06:52 AM
DC2 12
Jan 10, 2006 01:10 PM
