are my cylinders good?
saw this on my exterior cylinder walls and i was wondering if they are still good?
can u just put a block guard on it and use it like it is?
can i have it chamfered?(chamfering process)
cylinder 3
cylinder 2
cylinder 2 & 3
cylinder 3
cylinder 2
cylinder 2 & 3
is it possible to weld it?
sleeveing is done at a machine shop... its is pretty expensive though... around 1k for the parts and labor. i wouldnt just weld on a block and cal it good.. to much to be lost.
thats what i was thinking. i can just add material by welding it on. but will it warp the cylinders?
Not only that but distortion of the block casting itself. My advise is sleeving the block, if you're tight on dough, then you might want to purchase another stock block. Whatever you do, NO welding, not even with a block guard.
****. so a block guard wont do much help???
i just dont want those 2 cylinders to get worse when its in the car.
so will a block guard help keep it as is?
A block guard will not help you with you're problem, you're issue is going to be sealing. Like I said, you should get it sleeved if money isn't a problem.
