Shifter issue....need professional opinion
Old Apr 15, 2009 | 07:50 PM
Praetor353's Avatar
Default Shifter issue....need professional opinion
this is for a 96 civic DX....d16y7 engine/tranny, all stock
i have a problem. the shifter flops around like crazy left and right, even when in gear, but goes into each gear fine. it seems like the invisible 1-2-3-4-5-R gate is missing (if you dont know what im talking about, look at a lambo shifter gate>>>http://image.importtuner.com/f/edito...shift-gate.jpg. i ordered a bushing kit from energy suspension thinking it was that, but now that i get under the car i see it is clearly not. is the problem inside the tranny? or do i need a new shifter assembly? thanks all. there is a third possibility, i got the wrong kit. but i doubt that. its the 3 piece kit from energy
thanks all
Old Apr 15, 2009 | 08:22 PM
Murk 'EM's Avatar
Default Re: Shifter issue....need professional opinion
same **** happens to mine.. i got the shifter bushings and nothing changed i think its the bitch pin that holds the linkage on to the tranny but im not 100% on that
Old Apr 15, 2009 | 08:33 PM
Praetor353's Avatar
yeah man im gonna go look at that right now, every so often i have a rattling coming from the tranny (i think, it comes and goes) do you have that to?
....anyone else with the problem?
Old Apr 15, 2009 | 08:34 PM
mugen si's Avatar
you guys might want to make sure that the shifter ball isnt worn. and also replace the SEAT(bushing), CHANGE LEVER BALL (part# 22868).
i had this problem with my em1 shift linkage. replaced the bushings w/ energy poly's and replaced the bitch pin and still had the problem. i pulled the lever and realized that my shift lever ball had worn excessively. i replaced w. a s2 lever and put in a new ball seat/bushing and it solved the problem. goodluck!
Old Apr 15, 2009 | 08:38 PM
HondaGuy951's Avatar
x2 perfect answer right there! did the exact same in my em1! no more problems!
Old Apr 23, 2009 | 04:46 PM
Praetor353's Avatar
bought new seat and installed along with the bushings...problem fixed :D thanks guys
Old May 18, 2009 | 08:32 PM
sal_87's Avatar
where did you buy the seat and bushing im having the same problem thanks
boarding2008
May 26, 2009 04:04 AM
DirTyPreTTyThinGs
Aug 15, 2007 08:35 PM
gsrboi80
Jul 27, 2005 10:20 PM
scttydb411
Feb 12, 2004 09:01 PM
