Thread file
Old Apr 15, 2009 | 04:16 PM
adam00's Avatar
Default Thread file
has anyone ever used a thread file? i need 1 to fix some threads but i dont know how good they work.
Old Apr 15, 2009 | 04:33 PM
Bakeoff's Avatar
Default Re: Thread file
Yeah, they work great depending on the application. What are you working on?
Old Apr 15, 2009 | 04:45 PM
adam00's Avatar
it for my quad 2006 yfz450 i have to fix the threads that hold the front sprocket on. i was going to use a rethreading die but the size i need is like $45
Old Apr 15, 2009 | 05:38 PM
srmofo's Avatar
something like that I might just get the die....In my experience the files are difficult to use if you cant hold the item in your hands to hold pressure against it while you file the threads, It might just be me, I dunno....How much is the file you need? It might be worth giving it a try if it isnt too much.
Old Apr 15, 2009 | 07:26 PM
adam00's Avatar
The thread file i need is like $10
Old Apr 15, 2009 | 08:04 PM
Linh.'s Avatar
Dont get the file cause its only 10 bucks. Using the die would be the best way to do it.
Old Apr 15, 2009 | 08:05 PM
Karl Buchka's Avatar
I have dies for most common metric bolts under M14, but the thread file I have is an awesome catch-all for cleaning up threads on bolts I don't have dies for. If you want to do it right, get the die, but if it needs to be finished yesterday, break out the file.
Old Apr 15, 2009 | 08:31 PM
KFMRC's Avatar
I am going to out on the limb here and say that the threads on the countershaft are probably pretty hard and may not file that well. Are you sure the nut isn't the problem? It would be the softer of the two and be more prone to being the prob.
Old Apr 16, 2009 | 05:10 AM
adam00's Avatar
both of the threads are messed up but i bought a new nut
Old Apr 16, 2009 | 09:52 AM
Brad Campbell's Avatar
What thread? I can check the tool crib, and I'm in Durham/Glastonbury, CT this weekend.
Old Apr 16, 2009 | 12:02 PM
adam00's Avatar
m20x1.00
Old Apr 16, 2009 | 05:54 PM
srmofo's Avatar
heres an idea , someone else told me for a lefthanded thread.....If you can get another NEW nut or 2. Take them and file several lines through the threads of the nuts (perpindicular). It will sort of resemble a thread chase and if you take your time, use cutting oil, and back it off often to clean the threads and remove the slivers....if the threads are not too gummed up it should work
Old Apr 17, 2009 | 03:09 AM
Sorry. I didn't have that size.
Old Apr 17, 2009 | 01:54 PM
adam00's Avatar
does anyone know of a place in CT that i can get a thread file at
Old Apr 17, 2009 | 02:48 PM
abnaasefmb's Avatar
http://reviews.sears.com/2328/00942275000P/reviews.htm
i have one of these, use it all the time, it's a great kit for the money.
Old Apr 17, 2009 | 04:57 PM
88Hatchy's Avatar
I would at least try the thread file, they have always worked for me. If it doesn't work then you have thread file to use in the future. Just take your time when using it.
wkd astra van
Jul 29, 2009 09:30 AM
VtecbOi
Jul 10, 2006 04:31 PM
nk2k2
May 12, 2006 04:50 PM
ladius
Welding / Fabrication
Oct 23, 2005 01:11 AM
ciRcuitJerk
Mar 14, 2003 12:53 PM
