Code 1,4,and 43 on a 92 accord ex
I took my car in to a local honda shop and they said it was throughing those codes, Heated O2 sesnor, ignition output signal and Fuel supply System... The car does overheat when idling, but the fans and everything works, Could it be the Thermostat??
I recently replaced the igniter..so i'm not sure why it throws that code.
But the main issue, is the fuel pump. what the car does is after the car has been running for about 20-30 minutes, the car keeps cutting in and out, more like its choking...it also seems to die out when its at a quater of a tank when i make a stop..could it be the fuel pump or could it be something else?? If it is the fuel pump, how hard is it to replace? I know it cant be that hard, but i'm not sure where it is (under the rear seat??) and how much does an aftermarket fuel pump run??
H-T never lets me down! Thanks in advance!
Justin02Accord
Aug 7, 2017 10:01 AM
oldfart
Jul 14, 2005 08:20 PM
