need 02 sensor wiring after b16a swap
okay so i had a 94 sohc vtec civic. put in a 93 b16a engine with its p30 ecu from a del sol. can anyone help with the 02 sensor wiring. im getting a code 41 for sensor heater. old 02 sensor from sohc engine had 1 wire this sensor has 4
i'd also like to know, i'm assuming you take the wire from the single wire harness and connect that to the black, the ground is pretty much a no brainer, but where do you pin the two white wires to? i'm about to do a swap on my brothers car and its a 92 dx with a single wire o2 and is going to need the 4 wire conversion.
ok sorted out my problem. all i had to do is find the orange and black wire from the engine loom that didnt go to the ecu from the cars loom. connect that wire to pin 6 on connector A
xgsrturbox
Apr 8, 2006 11:01 PM
