Milling head
Old Apr 14, 2009 | 07:01 PM
97twodoor's Avatar
Default Milling head
Hi, I am wondering if I mill .020" off of my GSR head if I will run into any piston to valve clearance issues. The head will be going onto a stock compression B18C1. Also will I need adjustable cam gears to get the cam timing back to the factory location?
Old Apr 14, 2009 | 07:27 PM
DC_Legacy's Avatar
Default Re: Milling head
It's definitely worth claying the pistons to ensure theirs no P2V contact for peace of mind.
Old Apr 15, 2009 | 06:13 AM
97twodoor's Avatar
Anyone have experience with doing this?
Old Apr 15, 2009 | 09:58 AM
phoshyzzle's Avatar
i milled mine .030. i have 11:1 SRP pistons and flat faced valves.
Old Apr 15, 2009 | 10:12 AM
92cxturbo's Avatar
what cams? shaving the head or block will retard timing slightly.
Old Apr 15, 2009 | 12:38 PM
00Red_SiR's Avatar
All Motor Mentor
You won't have any p2v issues and with only .020" off the head, it will only retard your cam timing by 1/2 a cam degree or 1 crank degree. You can get by without adjustable cam gears if you want, if you're picky and want to spend the money, it's up to you.
Old Apr 15, 2009 | 05:15 PM
97twodoor's Avatar
Thanks for all the replies guys. I just wanted to make sure that I was going to be alright.
Old Apr 15, 2009 | 08:39 PM
omniman's Avatar
If you have oem gsr pistons you can mill the head .020 and be fine with stock cams but the oem gsr piston has a much shallower valve pocket than say a type-r or b16a piston so you won't be able to run aftermarket cams without having problems. Even if you don't mill most aftermarket cams will cause v2p contact. If your pulling the head its not much more work to throw some itr piston on your rods and put it back together and be good to go with all the aftermarket cam choices. Amen
Old Jun 5, 2009 | 01:15 AM
91ef92egnewb's Avatar
New User
can shaving a b18ls cause any problems
Old Jun 5, 2009 | 01:16 AM
New User
all the Honda guys around here keep telling me that shaving a Honda head will mess with the timing belt
Old Jun 5, 2009 | 06:45 AM
Natural Aspirations's Avatar
Not a problem, it is adjustable via the tensioner. Although I do not know how far you can go, I have gone .040 in stock applications including a GSR W crower 403's. Was not the best combination, there was no contact in my application.
Old Jun 5, 2009 | 03:40 PM
New User
thanks for the insight
neofreak
25
Jan 1, 2007 12:33 PM
thehatchninja
Jun 4, 2005 08:28 PM
lilredhatch
Jun 1, 2004 05:19 PM
mtber
Feb 28, 2004 12:11 AM
Speedz
Apr 9, 2002 07:10 AM
