The "Hella Flush" Look..
Old Apr 14, 2009 | 03:16 PM
2gnarly's Avatar
Default The "Hella Flush" Look..
..I'm trying to achieve the Hella Flush look on my 3rd Gen Integra. I seen this Integra around town and he was pretty flush w/o a ridiculous offset if any at all. (I don't know much about offsets so sorry if that doesn't make sense) Think he was running spacers? I want and aggressive stance with spacers (if needed) and a tasteful offset to achieve that look. So, what I'm asking is, what offset/spacers will help me achieve this look. Thanks in advance.
Old Apr 14, 2009 | 04:39 PM
acura_integra-gs's Avatar
Default Re: The "Hella Flush" Look..
like a +30 or 35 offset with ur car lowerd a fare bit should give u that look correct me if im wrong but what offset are your wheels now and how low is the teg
Old Apr 14, 2009 | 05:33 PM
TunerN00b's Avatar
Put car on jackstands.
Remove front wheel.
Measure exact distance from hub to fender edge, at your chosen ride height and camber setting (if adjustable).
Buy wheels and/or spacers to put the outer lip at that distance.
Roll rear fender to accommodate (rolled rear and stock front are very close in clearance).
Don't forget that you'll want extended studs and open ended lugs for anything more than a 5mm spacer.
Sorry, it isn't an exact answer, but it is the answer to go exactly flush on your car.
Old Apr 14, 2009 | 07:51 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
This is better suited to the wheel/tire forum, since it's not really Integra specific.
oscarcd5
Mar 12, 2024 03:17 PM
Dipsett
Nov 4, 2012 09:54 AM
DK-4LIFE
Honda S2000
Dec 26, 2008 06:48 PM
shamoo
Honda S2000
48
Oct 29, 2007 10:46 AM
RTW DC2R
Sep 8, 2002 04:07 AM
