..:: 92 Accord window glass problem - top corner round pin ::.. PICS - need advice
Old Apr 14, 2009 | 12:15 PM
mr2fanatic's Avatar
Default ..:: 92 Accord window glass problem - top corner round pin ::.. PICS - need advice
So my window in the 92 Accord recently appears to have popped off the track. I noticed that the round black plug or pin is gone. I believe that this is a guide that helps the window ride on its track. Is there a way to repair it? Should I purchase a new pin and guide from Honda or will any pin/guide work from a integra or other honda model? Attached is a pic of the problem. Any insight would be great. Thanks in advance
Old Apr 14, 2009 | 12:58 PM
dafang's Avatar
Default Re: ..:: 92 Accord window glass problem - top corner round pin ::.. PICS - need advic
Same thing happened to mine and I just fixed with a bolt from ace hardware. You will have to find the device that bolted into the hole. It should be stuck someplace in the window groove track
Old Apr 14, 2009 | 07:17 PM
Freshagen's Avatar
You can go to the honda stealer ship and get those parts for like 10-20 bucks. it's easy to install. I've done it.
you just gotta unscrew the track, screw the bolt in. glue the track back down, screw it in again. and good to go. some ppl say you gotta take the panels off b/c you'll scratch the window but i didn't... may be different for sedans and coupes tho.
check your junkyard, good chance it'll be there
Old Apr 14, 2009 | 07:37 PM
redbull-1's Avatar
It's not too bad at the dealer.
Old Apr 15, 2009 | 12:32 PM
dafang's Avatar
Old Apr 15, 2009 | 07:31 PM
mr2fanatic's Avatar
thanks guys for your help!
I'll post back here when I get the parts and install
Old Apr 17, 2009 | 07:13 PM
stereo69's Avatar
thats the guide on a 4 door the OP has a 2 door coupe and is refering to the pin on that the glass slides on the back side of the door. this should be the right parts.
73341-SM2-A01 BRACKET, PIN GUIDE
73344-SM2-A00 SEAL A, PIN GUIDE
Old Mar 13, 2012 | 02:53 PM
NycNyc92's Avatar
my guide pin broke on my car as well and im just trying to make sure i did this right since the only one i could get was $18 i wanna make sure im doing it right. so please give me steps on how to replace the guide pin. thanks
n20capri
May 6, 2024 11:58 AM
mmedcalf
Dec 19, 2015 08:17 PM
Cris423
Nov 11, 2014 05:45 AM
odyssey1403
Feb 19, 2010 09:41 AM
windcalmer
Aug 7, 2004 03:22 PM
