Snapped Crank Bolt
Old Apr 14, 2009 | 07:14 AM
InvaderTrax's Avatar
Default Snapped Crank Bolt
Long story, but I managed to break the head clean off. There's plenty of meat in the crank, plus a little hanging on the outside. Do I have a chance of getting it out?
Old Apr 14, 2009 | 09:24 AM
mouab18c1's Avatar
Default Re: Snapped Crank Bolt
is the motor out of the car? i have to say its almost impossible now
Old Apr 14, 2009 | 10:09 AM
Dark_Teg's Avatar
Ground the bolt down till there is nothing left but the stud portion. The stud itsself shouldnt be very tight.
Then simply drill a hole in it and use an ease out.
Old Apr 15, 2009 | 07:48 AM
jweller's Avatar
weld a new nut onto the remaining portion of the stud. EZ-outs scare me to death, I think they end up causing more problems than they solve
Old Apr 15, 2009 | 10:15 AM
Motor is in the car
Old Apr 16, 2009 | 10:15 AM
mouab18c1's Avatar
if its still drivable, then drive it to a shop and have them take it out..your best chance
Old Apr 16, 2009 | 07:55 PM
No chance am I driving anywhere without a bolt holding that pulley on. The most I did was move it 15 feet up my driveway, and I did that as quickly as I could (I actually just got it rolling them shut it off and rolled to the end)
Old Apr 16, 2009 | 08:53 PM
jlude90's Avatar
i'd try and easy out, just be smart
Old Apr 16, 2009 | 08:55 PM
dtapia's Avatar
if you didnt cross thread the bolt then you should be able to back it out by hand since the bolt does not bottom out in the crank.
Old Apr 16, 2009 | 08:58 PM
TravisCadello's Avatar
wow same happen to me i got a new block after welding it on twice and it came off lol. and why are u scared to move it? the only thing important that it spins is the alternator. only thing that will happen is the battery will die after a while. 2 hours.
Old Apr 17, 2009 | 06:53 AM
mouab18c1's Avatar
actually if you only broke the back end off then im sure its still tight. if not then the whole thing should have came out instead of breaking....try to see if its still nice and tight...
Old Apr 17, 2009 | 09:33 PM
It also holds the timing belt...
Old May 8, 2009 | 11:26 PM
I ended up towing it to a shop. They had a lot of fun doing it. They ended up drilling it out step by step until they could grab the threads and peel them out, then chase the threads. Charged me for 2 hours which wasn't bad
Old May 9, 2009 | 06:28 AM
KWayRacing's Avatar
So they used a left hand drill bit and it eased its way out until they could just grab it. Hmm. Either way it is fixed. As stated earlier unless you are equipped with high quality bits, taps,dies, most often bolt removal is best left to someone more on a professional level with more experience to know not just what to do, but what to definately NOT do. Wow that is one awkward sentence.
SxualChkL8
20
Mar 24, 2007 07:47 AM
Johnny Groovez
Sep 14, 2006 10:50 PM
SKDRCR
Jun 7, 2005 05:22 PM
david90
Sep 30, 2003 03:25 AM
Carp
Nov 6, 2001 02:37 PM
