what oven TEMP. do you need to loosen the headlights to do the jdm version and take out eh orange on
I am going to do the jdm versoin and I know some one who did this they put the headlight in the oven to loosen the glue and I would like to know what temp I have to put it in there at and If I need to let it pre heat or not and the reason I am askin this is becasue I cant get in touch with the persons that did this. And a friend needs this done thaks alot.
[Modified by turbo924porsche, 6:19 PM 8/15/2002]
Yall, tonite on the Home cooking channel, were cooking headlights! Yes you heard us right, headlights. here are the preperations:
preheat oven to 325 degrees
Have some tools ready, flat head screw driver, and phillips.
Remove ALL light bulbs and rubber sealent covering the bulbs.
Now were ready for some homestylin cookin!
Once the oven is preheated, set that **** headlight in there for 7 minutes.
When its done, pull it out and use the flat head to pull up the tabs and then once thats done, oull that shiznit apart. then start unscrewing and remove the bulb corner and side marker.
put back together and reheat for 3 minutes. hold lamp together while it cools down to restick
repeat for other side
heres other guys desprictions:
http://home.mpinet.net/t-hero/Headlights!!.htm
but he used a hair dryer (ull be there forever)
-jesse
-jesse
Dont the healights fog up after you take them apart??? How do you ensure a good seal???
thanks keep them coming I would like to know if it is 325 or 225 thanks alot
Wow, just don't let your mother or wife see you use the oven for that.
[Modified by SLPR, 11:16 AM 8/15/2002]
i guess it'll work, but I used a heat gun. and i know you can use a hair dryer.it may be a better idea since you get even coverage on the entire headlight, instead of slowly working your way around with the heat gun/hair dryer.
go for it, let us know how it turns out
i suggest you set the temp to 250 for about 7 minutes. i tried both already... 250 and 350. at 350 i kinda melted parts of the headlight but nothing noticeable.
how did you do a write u p3 weeks ago when you have only been a member for 6 days moron
