Timing Belt
Old Apr 13, 2009 | 07:39 PM
egotistic's Avatar
Default Timing Belt
nub question.... just want to be 100%
Is the timing belt the same for a JDM B18C R, and USDM B18C5 ? I have a 97 JDM b18 and am chaing out the timing belt a water pumo befor install....just want to be 100%. are all the b18 series timing belts the same 94-01?
Old Apr 13, 2009 | 08:08 PM
BlueIntegraBoy's Avatar
Default Re: Timing Belt
B16B, B18C, B18C1, and B18C5 all use the same timing belt.
Old Apr 13, 2009 | 08:22 PM
egotistic's Avatar
thats what i was thinking..... then i saw this
http://www.honda-acura.net/forums/en...geability.html
seems the r belt is a lil longer?.... or is that dude wrong?
on another not what is a good aftermarket replacement belt?
Old Apr 13, 2009 | 09:44 PM
egotistic's Avatar
anyone else have any insight?
Old Apr 14, 2009 | 08:45 AM
egotistic's Avatar
anyone.....?
you think a aftermarket timing belt is good, or is the OEM one good for a mild setup?
also when changing timing belt what else you recommend changing besides water pump?
Old Apr 14, 2009 | 09:08 AM
Utilitarian's Avatar
Originally Posted by egotistic
anyone.....?
-spark plug grommets (big rubber washer things)
-valve cover gasket
-tensioner (around $60 IIRC)
-new coolant
Old Apr 15, 2009 | 07:03 AM
jomama's Avatar
go oem with the timing belt unless you know you're getting a HIGH quality one elsewhere.
Old Apr 15, 2009 | 07:23 AM
kaj's Avatar
kaj
I use the same timing belt for USDM and JDM engines. We ran 500+whp with OEM timing belt. Never had a reason to go aftermarket.
+1 on replacing all gaskets.
Old Apr 15, 2009 | 02:05 PM
nsxtasy's Avatar
H-T Order of Merit
In addition to the above, I recommend changing the two big radiator hoses, and maybe even the small ones too. It's good preventive maintenance (better than having them fail on the road) and a suitably long maintenance interval. Plus you're already flushing the coolant and water pump so there are some savings in coolant and labor.
imadigitalgod
Aug 18, 2023 08:01 PM
Comp97GSR
Dec 30, 2022 12:10 PM
