EG & DC Intercooler piping
Are they the same if the EG has a GSR in it? I have a lsv turbo 94 teg and want to transplant everything into a 93 EG. Anyone have any insight on whether the IC piping and the IC itself should all fit with no problem? Thanks in advance.
Most of the EG's I have seen had the charge pipe coming through the same area where the ABS Motor is on Integra's, as long as the piping goes under the frame and over the tranny you should be ok.
The integra wasn't fitted with ABS, so I think everything should bolt up fine. The IC on the teg is bolted under the front bumper brace, and the EG doesn't look like it has the same clearance behind the bumper, but if I have to cut into the brace, that'll be fine.
