E-Brake Issue
Old Apr 13, 2009 | 08:30 AM
bopbop93030's Avatar
Default E-Brake Issue
Do I need to remove the rear caliper to fix the e-brake?
Apparently it was put back the wrong way. So when you engaged the e-brake the right rear is not engaging and the cable in the console is not even, the left side is working but the right side is way off.
Do I need a special tool like a brake spring compressor?
Old Apr 13, 2009 | 03:24 PM
alkoholikwun's Avatar
Default Re: E-Brake Issue
with rear drum brakes, you will need a drum brake spring tool, looks like a plier but one end is curved. it is possible to do it with regular pliers, if you know what your doing, but it is a little more difficult to grab the spring correctly.
Old Apr 14, 2009 | 07:17 AM
I have a disk brake, and do I need to remove the brake oil?
Old Apr 14, 2009 | 08:35 AM
bdmlilburn's Avatar
nah if its a disk brake then you can simply unbolt the caliper and hang it from the suspension with some speaker wire or something. this way you don't have to remove the brake fluid lines
imadigitalgod
Sep 5, 2010 02:42 PM
cheapo23
Jun 2, 2010 09:28 PM
miksew
Oct 7, 2006 11:46 PM
antivic
Jun 28, 2005 10:51 AM
turboD16
Sep 4, 2002 08:44 PM
