D15 parts onto gsr
Old Apr 13, 2009 | 07:11 AM
grant97teg's Avatar
Default D15 parts onto gsr
I have a alt/starter/vss from a 92vx and was wondering cause its obd1 that if
i run my gsr setup as obd1 that those parts would work? Thanks
Old Apr 13, 2009 | 08:01 AM
94_db8_GSR's Avatar
New User
Default Re: D15 parts onto gsr
no, single cam to b series wont interchange... if you have a 97 teg, its actually obd2a.
Old Apr 13, 2009 | 08:06 AM
grant97teg's Avatar
I know but it will be wired from a d15b harnes. So i figured at least the alt
would work if it will bolt up and sits right.
Old Apr 13, 2009 | 08:25 AM
94_db8_GSR's Avatar
New User
it might plug in, but not bolt in... due to the hole not linin with the brackets.. careful though, i think the amp out put is less than what a gsr needs.. so i wouldnt do it.. where you located?.. some1 usually has 1 layin around.. but make sure if you find 1, that you use the rightful brackets.. in etc. ls alt with ls brackets, gsr alt, with gsr brackets, they are different. good luck!..
Old Apr 13, 2009 | 12:37 PM
grant97teg's Avatar
I live in madison wi. Thanks for the info
Old Apr 13, 2009 | 07:50 PM
hondaZvic's Avatar
yeah hes right about that not bolting in... if u use that alternator, u will need a custom bracket. totally possible.. we run d-series alts on H's..
if it dont plug in then wire a new one in.
this is the Hybrid forum.
knuckk
Jun 1, 2008 02:39 PM
Bull_head360
May 22, 2005 11:11 PM
slammed00si
Jul 13, 2004 02:14 PM
jedi27sith
Apr 8, 2003 10:42 PM
