b16a2 comp. and gsr ????
Old 07-13-2004, 01:30 PM
slammed00si's Avatar
Default b16a2 comp. and gsr ????
ok my engine is dead in my civic.
im getting a gsr motor and putting it in my car (00si)
will i be able to use my stock computor on my gsr or will i run to lean? or run into other problems? i will probably swapp the b16cams into the gsr head if that would help it stay intune with the comp. let me know what you guys think.
Old 07-13-2004, 02:10 PM
pane93civhb's Avatar
i wouldnt do it if u are getting the gsr run that computer. better i think fa shore.. and its made for the gsr as long as u get an obd 2 gsr u should have a direct bolt in swap.. man.. it will be nice.. or u could probably use ur engine harness from the b16 on the obd1 gsr engine.. that would work also anyways.. good luck either way..
im so tired of doing swaps im on number six in one year and i dont have a license or get paid for this ****.. ha.. but its all fun.. love my honda..
Old 07-13-2004, 02:14 PM
* B A N N E D *
showtymers619's Avatar
Default Re: (pane93civhb)
wont run correctly you will run lean and your secondaries wont open.. but you can drive on it down the block and it shoudl start up
a/k/a Jomo
Mr Hammond's Avatar
Default Re: b16a2 comp. and gsr ???? (slammed00si)
Well first off the GSR computer is already tuned for the dual stage intake manifold and it's going to be a richer program because of the 1.8L of displacement and more aggressive cams. Don't swap the B16A cams in. Why can't you just use the GSR computer? If you didn't get one buy one. Or if you have the money but a quality I/H/E and Skunk2 manifold and get a chipped P28 and afc or Hondata. You'll be glad you did. I would not run you P2T ECU.
JdmBoii253
07-17-2013 02:00 PM
million
04-09-2007 08:49 AM
crxjake
01-27-2004 04:41 PM
Quick Reply: b16a2 comp. and gsr ????
