poormans type r cams??
got a gsr block wit itr pistons arp full bottom end nd a b16a2 head port n polish with retainers n seals stock valves so my question is what cams should i run because i dnt wnna b undercam or drop a valve stick wit da b16 or itr????
wth if i was trying to do gsr i would of left it alone i got a gsr block nd b16 head im not sure wat cams to run i jsut need peoples opinions
No...what you NEED is some BASIC knowledge of HOW TO CHOOSE A CAMSHAFT THAT COMPLIMENTS YOUR ENGINE PACKAGE. Don't just come on here and ask a question, and when you get a good answer, you get a f*cking attitude with the person answering you.
im not get n attitude im just saying bro who would build poormas gsr???? cuz ive seen guys use a diffrent intake cam for ther exhust so i was wonder n
haha, sarcasm can be tricky sometimes.
im jacking this thread because its old and i dont feel like making another one
my questions are....
does a stock B18block and stock B16head just mate perfectly?
without any other things like pistons, head studs, etc...
can i use the stock GSR head studs?
same timing belt?
use GSR head gasket? or b16 head gasket?
will a Blox Intake Manifold for GSR fit on the B16 head?
and also DC Sport header for a GSR fit on B16 head?
any vtec problems? or other wiring problems?
so basically my questions are fitment issues
i have these 2 pieces ready to go. just wondering if its really that easy.
same timing belt?
That is my motor. B18B block with the PR3 (b16) head. I would spend the extra scratch on a set or ARP LSVtec studs. Ive heard that the GSR headbolts are what you want to use if you dont run Studs.
I am running a Stock GSR exhaust Manifold so the Header should work. Also running an LS Head Gasket, GSR timing belt (new) and Water Pump.
p.s. Go with Golden Eagle or a Kit that works like Golden Eagle for the Oil Supply line.
same timing belt?
same timing belt?
They will mate perfectly.
Stock GSR head studs are fine but i recommend ARP
Same timing belt....
A GSR intake mani will not bolt up to a B16 head
All B series headers bolts up.
