Type R cams, GSR head, and turbo.. Good combo?
my new setup may consist of type r cams on a gsr block/head and turbo... what are the benifits and are they worth it to swap out the gsr cams and go with the type r cams... If its not , the I"ll probably just stick with the gsr cams and leave the head alone for the time being...
thanks..
thanks..
Re: Type R cams, GSR head, and turbo.. Good combo? (92HB_HB)
Keep your gsr cams and stock head, they are perfect for the street. Spend your $$ on good engine management
Re: Type R cams, GSR head, and turbo.. Good combo? (earl)
correct.
Re: Type R cams, GSR head, and turbo.. Good combo? (SIXTYdashONE)
I run GS-R exhaust and ITR intake, don't ask me why, I was a ITR JDM ***** at one point...I want ITR everything, even the ITR JDM moonroof
stan
stan
Re: Type R cams, GSR head, and turbo.. Good combo? (Flamenco-T)
i heard recently some guy on honda-tech made more power with itr cams i mean alot more like 20whp just swappin it in and tuning it can anyone see to this
Re: Type R cams, GSR head, and turbo.. Good combo? (GunMETAL_TEgRa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GunMETAL_TEgRa »</TD></TR><TR><TD CLASS="quote">i heard recently some guy on honda-tech made more power with itr cams i mean alot more like 20whp just swappin it in and tuning it can anyone see to this</TD></TR></TABLE>
It was boostfed, but it was on a b16 and he didnt test it with a gsr cam.
art
art
HT's Biggest Loser
Re: Type R cams, GSR head, and turbo.. Good combo? (Arturbo)
Keep in mind this hp was made in a car made to rev to 9500 on a big turbo. for a fun yet mild streetcar, gsr cams and a stock head will do fine, as earl stated above.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo »</TD></TR><TR><TD CLASS="quote">
art</TD></TR></TABLE>
Yes what Art said, I had 2000 Si cams then swapped to ITR cams. I have never tried GSR cams myself, a friend has on his 2.0 GSR set up and made 2 whp less and 15 ft-lb more torque swapping frm GSR to ITR. SO it's all about combination and your set up.
This is thread where I posted my ITR cam results.
https://honda-tech.com/zerothread?id=704660
I dont think it would be a bad idea. But to back it up is this right here. Also like anyone else would tell you that it all depends on your setup. Good luck on what you decide.
Check it out- <U> https://honda-tech.com/zerothread?id=704660 </U>
