blox turbo manifold
Old Apr 12, 2009 | 07:11 AM
hbyrd8701's Avatar
Default blox turbo manifold
has anyone made good power with this turbo manifold like under 430whp at full boost. i try to search but no luck. i like these manifold alot for the price and since i see some people that have rev hard manifold that made good power, i figure the blox can too
Old Apr 12, 2009 | 07:34 AM
hbyrd8701's Avatar
Default Re: blox turbo manifold
i forgot to add, on a stock gsr/lsvtec or a stock bore piston/rod combo gsr/lsvtec with a 57 trim 60/63 a.r turbo.
Old Apr 12, 2009 | 11:49 AM
hbyrd8701's Avatar
bump..... no one has a blox manifold
Old Apr 12, 2009 | 11:59 AM
Hobkins's Avatar
No I have looked into this, on a budget build you can grab one of these after awhile they can crack because of the cast iron. I have heard about this on a couple people's setups. If you wanted a real log manifold just go for the Inlinepro's. Top of the line for log manifolds.
Old Apr 12, 2009 | 12:24 PM
Ls_dx's Avatar
Id say run it if you already have it.
Old Apr 12, 2009 | 12:40 PM
stockb18c's Avatar
well acutally i havent heard of anyone crackin there drag cast manifold...and it not a log either i think they flow pretty good
Old Apr 12, 2009 | 01:52 PM
hbyrd8701's Avatar
i dont have it yet. A friend of mine has a blox manifold for 2 years on his stock untune b20 that made 368hp around 15-17psi and his never crack. Hell i had my tubler less than a year and it crack in two places. to be honest i never heard any castiron crackin. the guy that tigweld my manifold recommend castiron, beside retirer after 30 years from the airforce from welding aircraft
Old Apr 12, 2009 | 01:58 PM
Hobkins's Avatar
Blox is not a log manifold? Please explain.
And as for the cast iron not cracking this is just what I have heard, I've seen some pics of the cracks starting near the wastegate flange and heading down between the 2nd and 3rd runner.
Old Apr 12, 2009 | 02:00 PM
Hobkins's Avatar
I'd just go with the Inlinepro's they handle rediculous ammounts of psi and I haven't heard any negative things on them.
Old Apr 12, 2009 | 02:56 PM
project dc2's Avatar
dimensional 1 norman made 4XX WHP with one I believe
look under sefixcivic
Old Apr 12, 2009 | 04:01 PM
hbyrd8701's Avatar
^^thank you, that is what im looking for^^ did his manifold crack........
is there anymore out there..
Old Apr 12, 2009 | 06:28 PM
plenty of people making great power with cast style manifolds.
IMO the inline pro vs the blox, to be honest i dont think is a HUGE difference, both have a slight amount of direct runner flow. the blox has a great wastegate placement.
the bad thing is, you cannot put as big of a turbo on a blox manifold than you can on an inline pro because of its flange configuration and placement.
Old Apr 12, 2009 | 06:51 PM
Hobkins's Avatar
Some other thoughts on the Blox is you run into hood clearance issues with some wg's. Just another thing I remember reading from fellow h-t members.
Old Apr 12, 2009 | 06:57 PM
Bugermass's Avatar
A customer of mine had one on a stock GSR made 370HP on it..
Old Apr 12, 2009 | 06:58 PM
Hobkins's Avatar
Here's a thread I posted about a week ago. Mabye some of these comments will help you out.
https://honda-tech.com/forums/showthread.php?p=38053902
Old Apr 13, 2009 | 06:28 AM
hbyrd8701's Avatar
^^ I saw your thread a couple days ago. I didnt want to hijack your thread so i made this. Remember im not going for all out power, im just looking to make 330-350 on pump and on race gas around 400+ or whatever it make on high boost. As for upgrading turbo, the turbo that i have now is a keeper, SC34 57 trim 60/63
Old Apr 13, 2009 | 07:10 AM
b20beast83's Avatar
i would think it could make that power
Old Apr 13, 2009 | 07:55 AM
E85B18's Avatar
Some how I cracked my cast manifold. Here is the only pic i have right now, look in the corner and you can see I tried to re-weld it
Old Apr 13, 2009 | 10:34 AM
Hobkins's Avatar
Of course you could you get 350 - 400 on them... That's the goals I'm going for also. But my mind has been set to just spend an extra 200 for the InlinePro's. I'm sure the Inline's will last up to high hp with c16 and high boost. It's just one more thing that I don't have to worry about.
Old Apr 13, 2009 | 10:55 AM
run a wastegate elbow. same issue with the inline pro once you add on a boost controller and have to use the upper port on the wastegate
BmCRace.com
Nov 24, 2010 06:35 PM
magefa
May 19, 2008 03:20 PM
fin781
Dec 13, 2007 12:51 PM
Wicked671
Mar 29, 2003 12:12 AM
