Advice needed about manifold
Old May 17, 2008 | 02:44 PM
magefa's Avatar
Default Advice needed about manifold
building a B16A2 turbo...
thoguht of this mani , is it good?
Old May 17, 2008 | 02:53 PM
pumafeet10's Avatar
Default Re: Advice needed about manifold (magefa)
could be but probably not, is that an xs power mani? if so search on here and you will see how a lot of peoples fall apart
Old May 17, 2008 | 04:52 PM
Schister66's Avatar
Man U FTW
There are real versions of that manifold and there are rip-off versions of that manifold. From the one picture, i cant tell which you have.
Old May 17, 2008 | 09:12 PM
hondamn1320's Avatar
Default Re: (Schister66)
i have that same manifold. had it on for about 2+ months and it's still together working fine. i'd recommend turning the wastegate flange a bit so that the turbo can sit flush. that's the only problem i've had with mine so far.
Old May 18, 2008 | 11:41 AM
king06's Avatar
Default Re: (hondamn1320)
its an xs power mani, its going to break on the welds, unless you reinforce it.
Old May 18, 2008 | 01:13 PM
a1320honda's Avatar
Default Re: (king06)
I have had that manifold on my setup for over a year. It will crack in various spots with no bracing. But once braced, it has been a very good manifold for me. Just a good solid brace from the block to the turbo to support the bulk of the weight is all thats needed.
Old May 19, 2008 | 03:20 PM
Default Re: (a1320honda)
here is mine for reference.
Blove1991
Dec 19, 2011 06:50 PM
hbyrd8701
Apr 13, 2009 10:55 AM
fin781
Dec 13, 2007 12:51 PM
lkailburn
Welding / Fabrication
Jul 31, 2005 11:57 AM
SpecialGoodness
Mar 28, 2005 05:26 PM
