b20 vtec which power steering bracket?
Old Apr 11, 2009 | 05:15 PM
darrinbrewer's Avatar
Default b20 vtec which power steering bracket?
i have a b20z in my 96 civic, b20s use the same as d series civic power steering pump.
working fine right now.
i have a b16 head to go on now. what bracket will i need, and will i need to switch to a different pump? b16 si part number is differnet from crv
and the brackets appear different as well.
thanks guys
Old Apr 11, 2009 | 07:46 PM
kingofbattle909's Avatar
Default Re: b20 vtec which power steering bracket?
who needs power steering? it just robs torque.
Old May 2, 2009 | 07:40 AM
stelteg's Avatar
New User
hey man,
Im in the same boat as you are.
The b16 upper bracket will work, apparently.
Also, if you cant find that, use the integra type r upper bracket, as they are the same as the b16 bracket.
At acura the part number for the upper bracket on a type r is:
56997-p73-000 its roughly 100 bucks.
Goodluck.
Old Jun 26, 2009 | 08:05 PM
ended up all b16 brackets, lower and upper
and you HAVE TO use a 99-00 si pump because 96+sohc and 99-00 si pumps have the same pressure hose bolt pattern
yungkhmer
Dec 13, 2013 12:38 PM
boosted_LS95
Feb 17, 2011 01:36 PM
b16a3delsol
15
Feb 20, 2008 09:31 AM
wahabum
Apr 25, 2006 07:29 PM
ciph3r
Apr 15, 2005 11:47 AM
