Code 9 question and suggestions on next step (All motor JDM B16A CRX)
Old Apr 11, 2009 | 04:36 PM
ADAMnQuickRDX's Avatar
Default Code 9 question and suggestions on next step (All motor JDM B16A CRX)
Mods and a engine shot are below. Took about 5 months to finish this project on my driveway, working a few hours here and there with a buddy. Came out pretty clean and after chasing an issue of the car breaking up for weeks (turned out to be a loose ground wire), it's now running great. Pulls really hard and doesnt break up at all, idles well.
PROBLEM:
I still have a CEL though and it's throwing code 9 which I've read is "Number 1 Cylinder Position"....I'm guessing this has to do with the distributor. I haven't set the timing yet and cam gears are at 0. Do you think it could just need the timing set or should I source a new distributor?
Given the modifications below any ideas what I should do next? By the way it's still OBD0 so I think I'm pretty limited on the tuning. I was thinking maybe convert to OBDI and do cams and a tune? Definitely need to get a pro to align the car and also need to upgrade the brakes when $ permits.
CURRENT MODIFICATIONS LIST
ENGINE:
HONDA JDM B16A Engine / Transmission Complete Swap
HASPORT Motor Mounts & Shift Linkage
Integra Type-R Intake Manifold
GOLDEN EAGLE Fuel Rail
AEM Hybrid B-series CRX Air Intake
HONDATA chipped PR3 ECU Computer (OBD0)
MOROSO Oil Pan
ACURA Integra AXLES
ALUMINUM 1/2 Core RADIATOR
12" slim FAN
BLOX magnetic drain plugs
EXHAUST:
RS*R JDM Stainless 4-2-1 Exhaust Header
VIBRANT Stainless Steel Cat-back Exhaust
Test Pipe
HANDLING:
D2 36-way adjustable full COILOVERS
DRAG DR-16 Wheels
McGuard gold spline lugs
AVID Chromoly Pro-Series Traction Bar
BLOX Lower Control Arms
BUDDY CLUB rear camber kit
BRAKING:
RUSSELL Stainless Brake Lines
SHIFTING:
HASPORT LINKAGE
B&M SHORT THROW SHIFTER
ENERGY SUSPENSION Shift Linkage Bushings
SPOON Duracon Shift ****
saunders400
May 26, 2011 10:20 AM
ADAMnQuickRDX
May 7, 2009 11:30 AM
jdm-lab
Feb 21, 2007 09:45 PM
alexb16hb
Jul 22, 2005 05:15 PM
mugenbattle
Dec 13, 2003 06:12 PM
