94 Accord EX- need a fuse box diagram
I looked everywhere, and it's possible I just plain don't know what it's supposed to look like, but I think I need a diagram of the fuse box for my car- the one in the car, not under the hood. I bought the car last night, and it turns out neither of the front blinkers work, and I can't figure out why the CD player (aftermarket) won't work either. I thought a good place to start for both (open to suggestions of otherwise) would be fuses. I'm pretty new to working on cars, so please bear with me if I have stupid questions. Thanks so much!
Yes, it should say inside the door of the under dash fuse box.
If you don't have the owner's manual for other things, you can view it here:
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
Wow, I feel pretty silly, thanks! Now the problem is, all my fuses are fine, I still don't have front blinkers, and my CD player still doesn't work.
im sure you already checked the bulbs
... but when you put your blinker, does it blink at a fast pace or normal ... i would use a volt meter and see if your even getting power to the blinker sockets
So are all the turn signal lights out in the front (i.e., the lights in the bumper and the corner parking/side markers)? If so, it may be the turn signal/hazard relay located in the under-dash fuse/relay box.
You might need to check the aftermarket radio wiring. Here is a link to instructions to access the radio.
http://www.installdr.com/InstallDocs...PDF/466037.pdf
The fast blinking may be due to a bulb burnt out in front or going out, or corrosion in the sockets.
Oh I meant that in the car, like, the little indicator lights in the dash blink fast. I have no blinking action outside the car. I have headlights and nothing else, no corner blinkers, no bumper blinkers, nothing.
Pretty much new sockets all around. Although now my left headlight won't work, and when you put a bulb in it it takes out the rest of the lights on the left side, so I am assuming there is a bad ground in there somewhere; I will be checking that out Wednesday.
Yeah, maybe a ground wire, as the headlights & passenger turn signal share the same ground.
It was indeed the ground, as I had suspected. No, I still have no working CD player though. I think I am tackling that tonight. We checked all the fuses, connections etc. and everything seems to be in order, so we checked out the head unit itself, and it works fine in another car. Yesterday messing with it a little it made the "hey I'm on" noise once, then nothing, so I'm not really sure what's up with it, but I do know that driving to the sound of my own leaky exhaust is getting irritating.
svselva
Sep 29, 2005 07:37 PM
