my rsx type s is leaking water in the trunk
Old Apr 11, 2009 | 09:34 AM
ej1fury's Avatar
Default my rsx type s is leaking water in the trunk
does anyone no? or have u had the same problem i cant figure where its coming from ....helpthere is water filling my trunk ???
Old Apr 11, 2009 | 10:02 AM
dc5fosho's Avatar
New User
Default Re: my rsx type s is leaking water in the trunk
I had water in by the spare tire but never noticed the rear carpeting being wet - after i did a check with the garden hose i realized the water was coming in from the taillights - i ordered a new set of taillight gaskets from the acura dealership they had to order them and they came in in about 3 days and cost me around 30 bucks for the set - all you have to do is pop the taillights out and replace the foam gaskets and you should be fine assuming your car has never been in a rear end accident cuz if it was then you may have more problems than this haha - when you take your rear tailights out there are the nuts that you access from the trunk AND two screws that screw in from under the bumper into the taillight i was able to get mine out without removing the bumper - hope this helps and solves your water problem
Old Apr 11, 2009 | 11:24 AM
ej1fury's Avatar
word thank you man and it was in a rear end crash but wasnt very bad but thank you for the post...im ganna get the gasket and try that
Prudz_lude
Feb 8, 2016 11:19 AM
bad 91 teg
33
Oct 1, 2011 02:34 PM
x1aO
Mar 10, 2008 01:02 PM
effinnwackk
10
Jul 15, 2005 05:31 AM
AceP97
Jun 17, 2001 09:24 AM
