need help from sleeve installers
Old Apr 11, 2009 | 07:47 AM
ekb16's Avatar
Default need help from sleeve installers
i got this block from work that was hydrlocked. i finally took it all apart and found #1 rod was bent but all the other rods look find. it nicked the base of the cylinder pretty good and i was plannin on using this block as a back up motor and having it sleeved..my question is will this block still be sleeveable or not and will it most likely cause problems in the future.
this is the water passage behind the cylinder walls where coolant circulates..one of the guys says the block is junk cuz its cracked but it doesnt looked cracked..sorry the crappy phone pics
Old Apr 12, 2009 | 09:32 AM
Lubo_25's Avatar
Default Re: need help from sleeve installers
being that I'm crazy I would re-sleeve the block to sleep better at night...
Old Apr 13, 2009 | 08:04 AM
Darton's Avatar
There wiould be no problem having that block sleeved. That part that is damaged would get machined out.
Old Apr 13, 2009 | 01:39 PM
ekb16's Avatar
thank you
Txdragon
Engine Machining & Assembly
May 2, 2019 03:20 AM
sitinduk
Sep 2, 2010 05:08 PM
92BlackSi
Aug 31, 2003 08:41 AM
Desperado
Apr 27, 2003 03:08 PM
LS-G
Jun 8, 2002 04:55 PM
