92 hatch sways and rocks like a boat
Old Apr 11, 2009 | 07:45 AM
B16aCRXSi's Avatar
Default 92 hatch sways and rocks like a boat
i have a 92 hatch with a swap i just got it on the road and when i go 35mph or more and the wheel turns just a hair it feels like a boat rocking left and right side to side, but anything slower its fine. what would it be? hub bearings? i havent check the wheel while it jacked in the air to see if theres play, or is it the sway bars? or the end links? can anyone help me out, i feel like im gonna crack the car, i cant even take it on the high way
Old Apr 11, 2009 | 07:56 AM
waaBAAH's Avatar
Default Re: 92 hatch sways and rocks like a boat
check your springs and struts. broken and or leaking.
how long has the car been sitting?
Old Apr 11, 2009 | 08:08 AM
B16aCRXSi's Avatar
i just put brand new skunk2 sport shocks and skunk 2 springs, and there all in perfect condition, none were leaking broke nuttin. i litterly put them in like 2 weeks ago, and befor i put them on the problem was still there
Old Apr 11, 2009 | 08:10 AM
EjSex's Avatar
double check all suspension component bolts are tight...double check your lugs!
Old Apr 11, 2009 | 08:22 AM
B16aCRXSi's Avatar
lol, trust me there all nice and tight lugs are on tight 2
Old Apr 11, 2009 | 08:27 AM
EjSex's Avatar
are your wheels balanced? i slammed a pothole a few weeks ago, it knocked a wheel weight off of the rim causing it to be off balanced enough to loosen the lugs and create a world of problems for me... maybe you need to go get the tires balanced
Old Apr 11, 2009 | 08:28 AM
B16aCRXSi's Avatar
hmmm maybe, but its not a lil sway i mean its an up and down left to right, sway bar? end links?
Old Apr 11, 2009 | 08:30 AM
EjSex's Avatar
bad ball joints? my money is on broken axle, check your CV joints...
Old Apr 11, 2009 | 08:32 AM
B16aCRXSi's Avatar
hmmm i put a brand new axcel on my drivers side, but reused and old axcel for the pasenger side which was off a cable tranny but still fit and worked.... maybe
Old Apr 11, 2009 | 08:35 AM
EjSex's Avatar
yea, check them, i used to break them all the time in my b16a swapped ek coupe, itd buck like a horse and a i knew right away...
however,, idk if youre familiar with EKs... but the upper driver mount, (shaped like a tee-pee lol) always breaks and causes the same feeling as a broken axle...
but on EGs the mounts dont typically break...
B16aCRXSi's Avatar
and there is play with that axcl like its just a tad hair to short
Old Apr 11, 2009 | 08:37 AM
B16aCRXSi's Avatar
i know what your talking about, my axcel clicks when i turn anyway, maybe its time to put a brand new one in, but i dont think thats whats causing it to sway but im gonna change it out tomorrow
Old Apr 11, 2009 | 08:41 AM
EjSex's Avatar
yea, i dont see what else it could be, lmk if that fixes the problem, and while youre under there check the ball joints, everythings tight, check all your mounts (check the rubber inserts for any tears), make sure the lugs are good, the wheels balanced... aside from that, im not sure what else it could be
Old Apr 11, 2009 | 08:45 AM
B16aCRXSi's Avatar
upper or lower ball joints? and i have a 00 JDM b16b CTR motor in my eg6 with brand new innovative billet motor mounts
Old Apr 11, 2009 | 08:59 AM
EjSex's Avatar
ok i wouldnt worry about the mounts then... check upper and lower, but it seems like in this case itd be more likely for it to be the lower
Old Apr 11, 2009 | 12:55 PM
B16aCRXSi's Avatar
how about a new alignment? when i first got the car from the guy he told me it needs an alignment bad, i just drove it again and i swear it feels like a boat, the wheel moves when i let go of it and the response is slow and then it rocks left and right, theres play in the wheel, like its slow
Old Apr 11, 2009 | 01:02 PM
Jinx84's Avatar
New User
sounds to me like you need an alignment
Old Apr 11, 2009 | 01:13 PM
B16aCRXSi's Avatar
but like it rocks so damn bad like i dont think a ****ed up alignment can even make it rock this bad
Old Apr 11, 2009 | 01:31 PM
Jinx84's Avatar
New User
Im not sure man. It sounds to me like you've got a combination of things going. That axle you spoke of earlier, I think, definetly has something to do with it, along with your sway bars. If you take it in for an alignment, I think the mechanics there will give you a better idea.
Old Apr 11, 2009 | 01:51 PM
MonkeyMagic's Avatar
bushings, high-profile tires, alignment??
throw us some better info man
kjam978's Avatar
New User
You can find good deals on ebay 5 pc. strut bar kits. Made my 95 hatch feel like a new car along with new coilovers. Almost no body roll at all and makes steering feel way better too.
Old Apr 11, 2009 | 02:06 PM
B16aCRXSi's Avatar
lol lets see sittin on 2 14s in the front with dif size tires, and 2 13s in the back with the same size tires
Old Apr 11, 2009 | 02:18 PM
THIS is your problem.
the 70 series sidewall will produce a ton of lateral movement.
diff size tires on the same axle will create an unusual feeling, and then having a completely different size/mix on the rear as well.
i say half your problems would be solved with a decent wheel/tire package
Old Apr 11, 2009 | 02:25 PM
B16aCRXSi's Avatar
but theres play in the wheel, not loose play like theres empty space, but its like the steering is late and then it rocks like a boat
Old Apr 11, 2009 | 02:27 PM
B16aCRXSi's Avatar
what would be a good size tire for 15x7 rims? i dont want low profiles but i dont want huge freakin tires 195? or 205 or bigger?
