No Voltage To the ICM
What inputs is the computer looking to see to allow voltage to go to the ICM? I check for voltage at the ECU and there is nothing.
Any input and ideas are appreciatted. Thank you in advance.
does the ecu have good grounds, there are several, make sure all of them are good. Is it getting power? If the above 2 are good then I might throw another ecu at it and see if I get power going to the ignitor
